Re: 1996 Johnson 115 - won't go over 2500 RPMS - HELP!!
I used carb kits on all four. Blew them out, etc. I did not set the float to spec, didn't know there was a spec for height and fall. That could be a problem. I see the leak from the carb when I pump the ball. There is another leak somewhere that I can't see. How long does it take the temp to get above 207? SLOW sounds like it could be part of my issue but the one plug looking brand new and the others having fuel on them leads me away from that. In SLOW does the motor idle and start perfectly?
I don't know what the OIS system is?
I think the carb rebuild has to be done again...I rebuilt 4 115 carbs just a few weeks ago...they are still sitting on my desk right here...when i installed the new valve and seat the float was WAY WAY OFF..almsot made me think there was somthing way different about my parts...but i adjusted the float to the specs...
now the specs right out of the book are UP TO INTERPRETATION, i think
they show the carb upside down with the float intsalled, they have a line drawn coming off the carb housing and a line coming off the top edge of the float...the lines are PARRALLEL.. and they show arrows representing the dimension between the two lines and say + or - 1/32nds "
is that LEVEL plus or minus 1/32nds" or is that just the dimension + or - 1/32nds....BIG difference!!!! when i first installed the new valve and seat I could adjust the float to be level and have 1/4" gap!!!!!!
it matters because if left like that I could be limiting the amount of fluid in the bowl!!
I adjusted and adjusted till i got a 1/32nds gap AND a level float... I feel good about that.
OIS is the ignition system and the back of your motor should have a plastic cover with that label on it OIS2000 right between the heads!!
as for the 207* temp that is only relevant to what temp the motor needs to COOL to to DISENGAGE the SLOW system( and is only one requirement of TWO needed to dissenage SLOW) after the temps rose above 240* to activate the SLOW system in the first place....so there is no relevant time associated with how long the motor takes to
rise to 207*....
find your leak before you take the carbs apart again or even off the motor!!!!
the leak from the carb when you pump the ball??? exactly where is the gas FLOWING from on the carb when the p bulb is squeezed??
I was getting gas squirting out when i squeezed the bolb on my motor and traced it to a bad O-ring in the fuekl bracket under the brass nozzle
good luck
report back
bob
