1996 Johnson 130 Shift Rod
JDusza
Hi, guys
I need to replace the water pump impeller on a '96 Johnson 130. I have the lower unit loose except for the shift rod. How do I disconnect the shift rod so I can drop the lower unit?
Thanks,
J
boobie
Re: 1996 Johnson 130 Shift Rod
Go to the port side of the mtr and look under the lower carb. You'll see the shift rod coming up to a cleavis. Remove the bolt in it and that disconnects the shift rod. Go to shop.evinrude.com and look up your mtr in the diagrams and you'll see it.
JDusza
I see it. I can access it with a long screwdriver.
This tells me the shift rod will drop with the lower unit (?). Ahhhh.....
Thank you. I am used to seeing junctions between the housings.
J
