1996 Johnson 150 no spark
The 25 / 35 HP models ( 3 cylinder ) show a different stator for rope / recoil / armstrong start models.----The 9.9 / 15 HP 2 cylinder 4 strokes use the same 2 stators as the 3 cylinder 25 / 35 HP models I believe.
boobie
Hey Guys, I'm still waiting for an answer ???? How about it Racer ????
you will need a DVA adapter for $25 on ebay and your in business. takes 30 min, max to find out if its the sensor, charge coil, or pack. rule out ignition coils on a non-sparking motor for now but as suggested above the service manual will walk you through it. don't bother with resistance tests just skip to cranking voltage tests to pinpoint.
