1996 johnson 25hp tiller friction screw was over tightened and wore it out now what?
rickjm1001
So it was over tightened and probably never greased so it's completely worm out and 40 degrees before and after it has a lot of loose play and becomes tight again.
This is with the screw completely tightened.
What can I do?
emoney
Re: 1996 johnson 25hp tiller friction screw was over tightened and wore it out now wh
What's wore out, the screw itself or the arm or? Maybe posting pics will help.
wilde1j
It's probably the upper liner or the friction block that's worn and it takes a bit of dis-assembly to get at it. See the parts list at BRP Evinrude website for more detail. Might be easier to hire a small boy to hold the motor.
rickjm1001
Well I removed the tiller and mounts from the midsection and what do you know, the person I bought it from over tightened the bolt breaking the brass friction block and I guess it was very loose. His fix was to install a bigger bolt and double the length then jam it far enough that it went past the brass block and into the steel shaft creating a grove in it :(
Its not to bad, so I'm going to replace the friction block and hope that everything will go back nice and snug :)
larryg
just make sure its all greased well and aligned,i had to redo a few times.
rickjm1001
What do you mean by aligned?
I didn't think I could adjust anything but have the shaft welded to resurface it and install a new friction block.
