1996 Johnson 70hp outboard motor (J70TLEU) fuel pump
golbrick7
My 1996 70hp outboard motor (J70TLEU) currently has a VRO fuel pump. Have disconnected the oil tank and pre-mix oil in gas tank. Is there a regular fuel pump I can use to replace the Original VRO pump as it needs replaced.
Look it up for a 3 cylinder model commercial motor.-----65 HP and uses a conventional pump.--------There are other options too.
Many of them including this site that you are on.-----Myself I would take the VRO pump apart for inspection before spending any coins.
