1996 Johnson 88 SPL, Tachometer
insearch
Where is the Tachometer signal coming from on my engine?
I can't find it in any of the electrical drawings.
The Tachometer does not register RPM's but I am not sure if it is the Tach or the wiring.
I have been systematically replacing wires due to corrosion.
I need to check continuity from the engine to the tach, where do I start?
Barnacle_Bill
Re: 1996 Johnson 88 SPL, Tachometer
Tach signal comes from the stator. The same leads (yellow) also feed the rectifier/regulator and the lead for the tach is normally made there. The most common problem for a tach to stop working is shorted diode(s) in the rectifier. Test procedure is given in your manual.
