mr300z87
Thread starter- Joined
- Sep 15, 2010
- 701
My friend has a 1996 Johnson 90 SPL on a Aquasport 17 center console that is having and intermittent problem running above 3000 RPM. The symptoms are a slight miss at idle barely noticeable if not used to the engine, when throttled up it will only get to 3000 RPMs and will not get on plane. After a minute it will start to rev up and will run 5100 RPMs. On today's run we ran for half hour slowed for a no wake under a bridge and then back to normal cruise RPMs. This was repeated again for a longer no wake and back to normal. Just before we returned to the marina we slowed and then tried to resume speed and it would not go above 3000 RPMs the entire rest of the way. This has been the case for the last few uses.
So far the mechanic at the marina has done a compression test and said the results are within spec, but I do not know exact numbers. A new OE fuel pump was installed. Today my friend the owner and I took apart the carbs (they were spotless inside) cleaned them blew air through all openings re-installed carbs, the results being the ride described above. There had been some discussion with the mechanic regarding a bad coil, which had been ruled out some how. We also tried opening the fuel fill, priming the bulb and applying choke while bogging none of which helped. It kind of seems electrical to me but do not know enough about these engines to go about diagnosing it further.
A little about me, my boats have been I/Os and even though it is in a boat they are easy to work on GM engines. The OMC 2 stroke outboard is foreign to me. I am hoping you guys can get us pointed in the right direction and as always any advice is appreciated. Have a great night
