1996 Jonhson 200HP spark on two cylinders only
jiffyboat
this motor have only two cylinder with spark.. the two on the center of each bank .. battery is full charged, and the motor turn fast.. I did disconnect the two rectifier wires , and still nothing .. compression is good ,I just got this boat and was seating for more than 5 years.. initially it was firing all the starboard bank and only the middle one on the port side bank.. but now only the two on the middle of the heads
Faztbullet
Remove all plugs and retest..if it has spark on all the starter/battery/cables have problems.....
jiffyboat
is exactly the problem that was found , the boat had a small battery 450cca , and I installed a big one 840CCA , and that motor now spins very fast., there is spark in every cylinder now.. thanks for the help
