1996 m30a3 tohatsu possible to splice two 7mm plug wires together
Wisc87-115-guy
Hi all i'm in a spot I trimmed to much plug wire off my cdi I know duh well anyhoo since a new cdi is 2 to 300.00 has anyone on here ever spliced two wires together by soldering etc the old inserts were corroded and I was going to replace the caps the plug wires on this cdi are molded into the body.
GA_Boater
In short - No.
What you might try is making a coupler with screw on spark plug ends. Use a cut off screw of the right thread to join a pair of tips and put some spark plug caps on the ends of the wires, then plug them together and insulate the crap out of it.
Wisc87-115-guy
Thanks for the reply im going to try some ngk spark plug wire splice kits look like tgey work.
Sea Rider
Although molded to CD, check if twisting the spark cable end CCW can set it free, sometimes are just fully screwed in to CD. Check if works ?
Happy Boating
TOHATSU GURU
Tohastu cd's and coils are epoxied into place. I've never been desperate enough to try and join spark plug wires together, but maybe it would work. The main thing is to make sure you use spark plug wires with sold wire cores. You cannot use carbon/graphite.
Sea Rider
Yep, and use same solid spark plug wire gauge. One idiot installed a motorcycle spark plug wire to one side of the Ignition Coil end ended screwing it. $ 70.00 after knows that he shouldn't mess with different spark plug wires gauges..
Happy Boating
