Hey guys, thanks for looking. Let me give you the history.
1996 Mariner 115 on a 17ft ChampioN bass boat. Stored for a long time. Cleaned gas tank. New fuel. New plugs. One can of Berrymans. Lower unit lube changed. And she fired right off and has run for two seasons. Idled a little rough, but very useable. Good holeshot.
Last week. Had a guy clean the carbs and slight adjustment per him. Big problem! Or more mistake.
Now I've had it in the shop and here are the details. Link and sync. Timing adjusted. New fuel accelerator and new fuel pump re-build. New regulator. Bulb and line new last season. New fuel lines. New fuel filters. Throttle cable and hot foot new about 3 months ago. Throttle cable adjusted for completley closed and WOT. New plugs NGK and gapped. Engines been on dyno at the shop.
Tech took it to the lake and adjusted also. Oil pump adjusted with in spec line.
5000rpm's at WOT
48-50mph WOT
trophy 24pitch prop
water pressure 15-18 WOT
carbs at 1 1/2 turns out
tech stated a little rich
idle in neutral is 1000 and very smooth
idle in gear is 900 and pretty smooth with motor level
starts easy
timing set exactly to factory specs
these rpms are per a new teleflex sportsman series tach, may be just a bit off
Now remember I did have a good holeshot. But, now it will slightly hesitate then stumble all on itself from idle(900rpm's) until 2000-2100rpm's then off it goes smoother than ever. Mid range and top end range is great! But I really need my hole shot back. The stumble is killing me.
#1 and #2 carb seems to have a problem, but as soon as #3 and #4 kick in it's great. That is what I'm assuming. i believe they kick in around that rpm range.(2000-2200rpm)
What else can I check besides the shop doing a carb rebuild which may or may not cure problem? Am I missing something? What is causing the stumble and hesitation in the low end carbs and holeshot? Is there anything electrical that controls the #1/#2 carbs upon hammering down the throttle?
Please help quick? Thanks!
5000rpm's at WOT
48-50mph WOT
trophy 24pitch prop
starts easy
