1996 Mariner 4hp FAULT - stops and wont re-start - Please help
EDDYSTONE EEL
Niggling fault please can someone help fing diagnose and suggest a repair
I start the engine it runs perfect both at idle and high revs in all gears but then after about 10mins it dies instantly just like pressing the stop button it pumps water very well
does not seem to overheat no other problems exept this one changed the coil had new plugs changed the petrol and oil
does not splutter it just dies instantly I have cleaned the carb once it has died it won't start for a long while 1hour plus, If you eave it for a few hours it starts first pull then repeats the same process as above.
Can anybody suggest the next things to check. I was thinking maybe a faulty thermostat (if it has one), not an expert but know way around it if advice is given
THANKS SO MUCH
Hope to be back on water with it soon, wont take boat out without the aux you see
James R
Re: 1996 Mariner 4hp FAULT - stops and wont re-start - Please help
Be sure you have the correct plugs. 2 stroke motors can be funny that way.
EDDYSTONE EEL
Hi
Thanks for the advice
the plugs are the correct ones and brand new so I rule that out
any other ideas welcome please
THANK YOU
EDDYSTONE EEL
Hi
Still no luck with getting it running right
any advice please
thank you
EDDYSTONE EEL
Hi
Still not had it running right
can somebody try to help me out please
thank you
DRIFTER_016
Sounds like a poor electrical connection.
Check that all your connections are clean and tight.
I had a similar issue with an '89 Honda dirt bike. It would run fine and then just shut off and not restart until it cooled down. I had it in the shop 3 times before they finally got it to cut out. It was a dirty connection (one of the bullet type connectors) They cleaned it with some 0000 steel wool and the problem never came back.
Intermittant electrical problems can be a pia. :mad:
It could be a problem with the shutoff switch wiring as well.
If it is a tiller model check where the wiring runs out of the tiller into the powerhead area as the wiring can rub and crack there.
This should give you a start.
