tidechaser1
Thread starter- Joined
- Jul 8, 2014
- 4
i just finished replacing my steering cables and went to start the boat and it did not sound like it fired at all so i tested a couple of plugs which were very wet with oil so i cleaned them and tried to ground them against the block and check for spark..nothing.
after trying to turn it over for maybe 10 seconds i heard a beep beep beep…which did not stop until i turned off the key. i did some research and someone had posted to check the kill switch as his did this same alarm tone which turned out to be just the safetylanyard was unplugged. mine does not have a safety lanyard on the control so i am not sure if there is something simple i am missing. the boat ran fine before removing the steering cables so i am guessing some wiring issue.
has anybody ran into anything similar?
and no..the oil pump works fine and the tank has oil..it will not start at all so it is not an oil sender etc.
thanks.
thanks.
