mrmamiller
Thread starter- Joined
- Mar 7, 2011
- 167
I have a friend who brought an overheat sensor to me for a soldering repair (he had to cut wire to get a socket on the sensor). I know nothing about how Mercury does their overtemp/overheat alarming, so here goes. The owner has had an overheat alarm, but the engine was not "hot" to the touch. The motor is a 1996 Mercury "Classic", 40 HP, 4 cylinder, 2 stroke; serial is 0C268772. The friend ordered a new overtemp sensor but what he got appears top be a temp sender for a gauge rather than the overheat switch. From the manuals that were available for viewing on this site, there are both types of sensors on this setup. But, there is not very much information concerning the checkout of the overheat sensor. I was assuming that the sensor would make continuity at alarm trip point. I placed the sensor into boiling water and it remained as an open circuit. Afterwards, I was reading "somewhere" that the trip point is 300 degrees F; can this be right? I need to know: 1) what is the trip point for the overheat sensor, 2) does it "make" on alarm or "break" on alarm, and 3) what is the audible alarm for overheat and is it different from an oil alarm and in what way? Any chance that this is an alarm module error and if so, any checkout procedure? Thanks for any help that you can provide. Mark
