1996 Mercury 200 EFI Overheating at idle.
vulpine
I saw some other posts on this but here is my solution for others. Engine only overheated after a couple of minutes at idle, not at full speed.
Temp was reading 140-160deg on heads using laser temp guage.
Changed water pump, poor condition but no better temp when finished.
Changed thermostats, gummed up with salt, replaced still no change in temp.
Changed poppet valve (water pressure relief valve) diaphragm also gummed up solid with salt, no difference.
Removed cylinder heads found waterways in heads bunged up with salt. Scraped out and poured on muriatic acid. Washed off and replaced, temp down to 105 deg. This engine had been in storage for three years. Obviously not flushed out before storage. The laser temp guage was the big help here. Also beforehand you could not hold your hand under the telltale stream it would burn your hand. Now I could hold it there all day.
sleepinin
Re: 1996 Mercury 200 EFI Overheating at idle.
Vulpine,
Are those temps in Celsius or Fahrenheit?
Texasmark
degrees F. If C (5/9 F - 32) something would be melting and 140F will burn your hand.....normal setting for household hot water heaters.
My 2c,
Mark
Texasmark
Vulpine, thanks for sharing this info. I had a similar problem and it was only a frozen closed thermostat.
You make a good point that I want folks to understand. When someone comes on here with a problem, we don't know all the details.
My first reaction to the post would have been to change the stat (prior to reading what all you did) based upon my experience with my stat and that problem.
Also, I am in fresh water; seldom think about the problems of salt water like I had when on the coast.
So folks, it helps to provide all the info you can to help those trying to help us get to the right answer. And, the folks that manage this site have mentioned that more than once. The more info, the better the diagnosis.
My 2c.
Mark
