1996 Mercury 9.9 Bodensee carb problem
xeddog
I have just acquired the subject outboard motor and have been getting it into running condition. The rope start mechanism was seized so I had to dismantel and clean that up. The shifter (tiller type) and throttle linkage were also seized and I got those all cleaned up and working. The next problem was the carb.
The carb was even difficult to dismantel, but I did it. Only damaged one part and that was the needle valve. Fortunately for me, the needle valve is about the only part left available for that carb from Mercury. So I managed to get it all cleaned out and re-assembled to find out that the accelerator pump diaphragm was leaking. *^%#$@!! It took a couple of weeks to find the part, but a very helpful Mercury dealer found one. At least, found a source for just about all the carb parts. That would be from Yamaha, the builders of the motor.
Anyway, got the carb all assembled and put back on. Pumped up the gas, and low and behold the motor started on the very first pull. WOOHOO! Had to adjust the idle speed a little but other than that it was great. Thing just idled beautifully. But! After leaving it to idle for a couple of minutes, the idle rpm started to slowly climb. After another couple of minutes the idle rpm had climbed probably 400-500 rpm. I assumed that it was just a matter of getting all the gunk cleaned out (the outboard had even been transported laying down tiller side up - oops). I adjusted the idle speed back down again and it was running . . .ok. The idle wasn't as smooth as it was initially, but it was acceptable. Even stopped smoking, which I assumed was due to being lain down on the wrong side.
Here is where the trouble starts. I decided it was time to test the two kill switches to make sure they worked. I hit the button in the end of the tiller and the motor stopped. Kool. Now just start it back up and test the other switch. But I could not get that mofo to start again to save my life. I tried everything I could think of but it just would not even fire any more.
The next morning I go out there to "play" with it some more. Just thought I'd give it a couple of pulls just to see what would happen. I backed out the idle speed screw a couple of turns just in case. Second pull that thing is running again. What the . . .?!?!? But once again the idle speed started to climb after a couple of minutes and a couple of minutes after that it was 400-500 rpm too high again.
The bottom line is that it seems like you get one start per day with this motor. If you get it started and let it run for any length of time, it won't start again the rest of the day. I have even gone out there 4 or 5 hours later and it still wont start. But if I wait til the next morning. . .pull,pull,prrrrrr.
So does anyone have any ideas what could be causing this? As others have mentioned, there isn't much in the way of adjustments on that carb. One air adjustment on the top seems to be about all. And the problems don't start until the motor starts getting warm. If you use this motor to cruise out to your favorite fishin hole, you'd better be prepared to spend the night. :)
Thanks in Advance and sorry I took so long,
xeddog
snake eater
Re: 1996 Mercury 9.9 Bodensee carb problem
I dont know much about your motor, but I would make sure you have good consistent spark. I had a tractor do that one time. after a few min it would act funny, and then you couldn't get it started again. turns out it was a bad coil after heating up.
xeddog
Spark is all good.
Not sure if this makes any diff, but I have found out how to get the motor started almost every time. In the morning, just have to give a yank or two on the rope and it will start. While watching it, I have noticed there is smoke in the exhaust. Not a lot, but easily visible. I initially thought it was water vapor, but I think it is mostly smoke. After a couple of minutes the rpm's will start increasing and I have to set the idle speed back down. I initially thought the rpm increase was about 400-500 rpm, but now I think it could be double that. Last couple of times it has really started running fast. But I have also noticed that when the rpm's start increasing, the amount of smoke in the exhaust decreases, and it may disappear completely. This may be normal for an engine with old, hard valve seals or whatever, but it is an observation. Anyway, once the rpms have increased, and the idle speed set back down, the motor will run fine for as long as there is gas (I suppose).
Once you shut the engine off, the way to get it started again depends on how long it sets. If 60 seconds or less, you can generally just pull the rope and it will start again. If it has been over 60 seconds, you have to turn the idle speed adjustment IN two full turns. Then the motor will start on just one or two pulls. But then, of course, the rpms will start increasing again and you will have to set it back down again in a minute or two. The reason it wouldn't start for me after the initial attempt is because I would pump the throttle and flood the engine.
xeddog
fishin-fool
i think i have the same motor doe yours have a automatic chock on it
