1996 mercury force 15hp getting hot
VivaLaMigra
There's a THERMOSTAT on the midsection behind that plastic thingie. Just two flat-head screws holding it on. Take it and the spring TF out. A 105 thermostat is nearly useless anyway, once you open the throttle that sucker better be open, too. Remember, Mercury's didn't have stats for decades - for all I know they still don't.
jerryjerry05
855676003That's the part # for the 2005 15hp. Mercury thermostat that viva says isn't in there.
They put the thermostat in there because it makes the motor run better at a certain temp.
They put it in there for a reason.
poida
Hi all
been away for a few days
exhaust cover is back on
awaiting cylinder head torque (Mercury should get back to me)
New thermostat
poida
jerryjerry05 thanks for the reply, i thought 225# was the temp the first time.
still no idea what 225in# or 18# is
I generally run in nm or in-lbs, can you clarify what the # is
Thanks
Nordin
225# is in lbs and 18# is ft lbs.
In metric about, 2,5 kp m or 23 Nm.
poida
Thanks all
had a hunt around on the net and found a few posts that said 130 inch pounds
https://forums.iboats.com/forum/eng...amefisher-9-9-hp-head-bolt-torque-and-pattern
this is a 9.9 of the same year and by the pic that is the exact head.
i torqued it to 130 inch pounds and gave it a run. Read 105-111dg fh at a high idle.
neighbour picked it up and launched and it ran well, has not hit wot yet but looks fixed.
Which head torque is correct is the next question, can anyone chip in confirm please, I can nip them up tighter quite easily
jerryjerry05
The 130 inch pounds is probably right.
What I posted was info for all the Forces I ever worked on.
Then Mercury took over and used their parts.
