hydra23
Thread starter- Joined
- Mar 18, 2008
- 42
engine J175EXEDB spark plugs QL78YC replace old t-stats with OMC 435491 gauge shows 10-12 lbs idle 800/1000 rpm.
If I bring revs up to 4000/4300 pressure goes up to 25/30 and the alarm goes off. (s.l.o.w. activate) pee hole is strong and engine is not hot to the touch no boiling water no hissing sounds.
flush thru pee hole without t-stats and water flows with ease.
Should I test without the t-stats or just go for the pump and impeller?
Next step is to test the sensor.
