Re: 1996 Rude Power Pack questions
I did do a test run with the new champions before changing the prop..no change..I then changed prop and posted the results. weight is 3080LBS with trailer and ready to go in the water..batteries + anchor + cooler + fuel and other little items. this is the expected weight for this boat, so no water logged foam..McKee Craft uses a closed cell foam that does not adsorb water.
The original tach was reading ok I think, I purchased a new one to check it, just to make sure, the instructions said to set it at the 6P setting which I have done. I have no reason to think the tach is wrong, both tachs are reading the exact same. all of the NGK plugs appeared to be in good condition and they all looked the same.
motor cranks up great and idles very smooth, runs smooth through all speeds but feels like it bogs out just before full throttle. My dad has a 130 johnson on a bigger and heavier boat and it is way more powerful and will out run mine. my motor feels like a 100 hp motor to me. once I get the seals in and the head back on I will test again.
I will also do another compression test..I did compression test when I first got the motor about 2 months ago and they were all with in 10 PSI, I think in between 90 and 100, 5 were real close with one being a little low but within tolerances. If any pictures would help just let me know what you would like a picture of if it would help any.
thanks again for everyone who has taken the time to respond to my post, I really appreciate it. Sparkie
