1996 seadoo please help
travis_p_99
i just bought 2 1996 seadoo's they both ran good for 2 tanks of fuel.then on the third tank "they burn alot of gas by the way" one of the seadoo's started acting like the clutch was slipping?? do they have a clutch? when taking off then motor rev. up takes a sec to plain out then will go fast but takes a while to get there. i looked around the water intake and there is nothing there.i did get some lillys in there before that and did the same thing but after removing them it started running good again.but only for about a hour then act like i have lilly's in thre again but none???
bbuurma
Re: 1996 seadoo please help
anything about a 3/4 of an inch will keep it from doing that . is the propeller bent? it souds kinda like it. that does it too.
lpavasko19
hey on the one you think the clutch is slipping their is a wear ring and the way to see if its that is your not as fast as the other on their a lot of bulbles the best way to say it is its like a traine slipping it runs good some times
