Re: 1996 SportJet 120XR crank balance
Yep, heard that from EVERYONE (but I will add that ALL Merc Racing 2.5's and Marine Cranks performance builds are balanced, and it helps alot), plus, I'm not normal. I wouldn't have bothered either, except the new Wiseco's were 18 grams apart from each other (tech says if they're within 75 gms of each other they're fine. Ya, whatever), new OEM rods were 23gms apart, etc... Between finish porting and balance (which Force never did on ANYTHING [to keep cost down]), should increase longevity dramatically, not to mention 5800+ rpm's will rock on the little jet boat ;-) And you're also right on that being one of the 9 formula's they use, but that particular one doesn't apply to two stroke or inline 4 bangers. I figured it out tho, thanks to Gary Hildreth and Bob at Scat Cranks. Thanks guys...T
