1996 Tohatsu/Evinrude 9.9 4 stroke oil change
Hoser762
My 1996 Evinrude 9.9 4-stroke needs an oil change. Online parts diagrams show a drain plug behind the starboard lower cowl. I pulled both cowls, there isn't one. OMC service manual doesn't even mention draining oil at all. Before I resort to sucking it out the dipstick tube, is there an oil drain anywhere on this '96 Evinrude by Tohatsu 9.9?
Hoser762
My 1996 Evinrude 9.9 4-stroke needs an oil change. Online parts diagrams show a drain plug behind the starboard lower cowl. I pulled both cowls, there isn't one. OMC service manual doesn't even mention draining oil at all. Before I resort to sucking it out the dipstick tube, is there an oil drain anywhere on this '96 Evinrude by Tohatsu 9.9? E10FREDC
I do not believe it was built by Tohatsu.----Oil drain screw is shown on port side exhaust housing..-------307551 is part #
Hoser762
I could be wrong about Tohatsu origin but that's what I was told. I am not wrong about the missing plug. There is no obvious drain on either side. E10FREOC
That be funny and strange.-----I have 3 of these motors.----I can find the drain plug !!!!----And the engine oil plug appears to be the same part # as the drainplug for the gearcase.
Hoser762
If you can find the drain plug, please do share the location.
Port side of the motor.-----Half way down the motor.-----Level with lower mounts.----Same plug as oil drain for gearcase.----Should be easy to find !!
Vic.S
I cannot find either of those model numbers but the drain plug is #24 in this diagram
oldboat1
Not sure, but drawing it up through the dipstick tube on your 4-stroke might be more efficient in emptying the crankcase.
The drain plug is at the very bottom of the sump.----It is on the PORT side of the motor.
oldboat1
What device were you thinking of using to draw it up through the dipstick tube?
pvanv
Tohatsu 4 stroke 9.9 series started in 2000. You may have a Suzuki Evinrude.
Hoser762
Racerone, thank you for the help. I found it. It was painted over and I was so obsessed with it being behind the cowl (that's what I was told) that I didn't see it. Once found, I felt like an idiot. Even so, thank you.
Not a ----SUZUKI ----Built motor either !!-----And JOHNSON marketed small 4 strokes built by SUZUKI from 2002 and on for a few years.----I do not believe EVINRUDE marketed small ( 9,9 / 15 HP ) 4 strokes built by SUZUKI.
pvanv
Looks just like a Suzuki Evinrude I worked on a year ago. I confirmed thaqt the LU drain plugs were not the typical 8 mm of the Tohatsu, but rather 10 mm Suzuki size.
