MobilePC
Thread starter- Joined
- Mar 6, 2008
- 11
I bought a used 1996 740GL PNCS EEM engine for my project sportfisher. Boy was I surprised when I pulled the distributor cap and found no wires going into the distributor at all. No points ? no pickup.
A bit a research and I find that this is an EEM ignition system and that the coil gets it's "firing instruction" from a timing sensor mounted on the flywheel cover, monitoring a timing ring mounted on the crack shaft, under the flywheel cover. The problem is that the flywheel cover on the engine is for an inboard setup and I need it set up for my 290DP-B I/O. I've added a couple of pictures of the 2 flywheel covers and here is a link to the 3 ignition system that were available for the 740GL:
http://www.volvopentastore.com/Igni...on_id.715058279--store_id.366--view_id.778998
So my questions are:
Do I need to replace the distributor, with one that has a pickup mounted inside? (like the 3rd setup in the above link)
-If yes, would I use the two wires that presently go to the timing sensor and hook 'em up to the new distributor?
Comparing the distributor bodies in the link above , I'm pretty sure that a pickup could be added to the existing distributor.
Any other ideas?
Any help would be greatly appreciated and Thank you for your time,
Any other ideas?
