1997 - 115Hp issues
Brock O
Hi Guys
Hard one to explain. 1997 115HP 2 stk...TLEOR
First started with the motor dropping a cylinder, we did find a coil had dropped and have since replaced it and another with a few leads, checked all the earth connections and wiring at power pack, new plugs etc since has been running sweat.
Few trips in and it seems to be intermittingly bogging down at low revs, almost the same problem but once it picks up its ok. Starts and ideals fine, good power right through to WOT.
After reading my previous post, last trip the Tacho has gone, sometimes will read OK, other times its bouncing all over the show, few photos, nothing on the VRO side, the oil from what I can tell is coming from the air intake, stick your finger in there and it comes out blue, was very messy like this when it was dropping a cylinder also. I've cleaned this before and can not find any external hose or motor leaks.
Any ideas appreciated, have always thought it to be spark, but am getting close to finally by-passing the VRO.
http://forums.iboats.com/forum/engin...95-johnson-115
