1997 120 force change L unit oil?
sreed382
Forgive my greeness .I have two screws on top.One is vent screw,other is level screw.I know were my drain screw is.If you look at the manuales the drain screw looks like a pivot screw.Please some kind soul talk me through this.
roscoe
Re: 1997 120 force change L unit oil?
2 at the top
1 even with the propeller shaft, this is the pivot screw - do NOT loosen or remove !! usually phillips a head
1 UNDER the bulge, at the lowest part of the bulge - the drain plug.
