dkonrai
Thread starter- Joined
- May 9, 2009
- 719
picked up the long shaft johnson 15 hp 4 stroke. it needs a lot of minor items, but the parts are so expensive compared to running a 2 stroke.
weight, it is 123 pounds, and my 92 30 hp weighs less, but twice the power hmmm. i bought the motor for 300.00 with the tank, but am ready to drop another 300 in parts.
check out this impeller that the po said was replaced
![CAM00145[1].jpg CAM00145[1].jpg](https://forums.iboats.com/data/attachments/176/176512-8a5e3617338ca8469730dff08f9d60fa.jpg)
![CAM00146[1].jpg CAM00146[1].jpg](https://forums.iboats.com/data/attachments/176/176513-e7f26c6fac286b3d0a30619caa9e83d6.jpg)
i need to change the timing belt, obviously the water pump, rebuild the carb, change plugs. i have to pull the ph to change the bad lower cowling seal.
why are there so many parts and plastic pieces?
question,
owner said that fuel kept getting into the oil. im assuming that the fuel diaphragm is shot. any thoughts?
here are some shots of the motor
![CAM00149[1].jpg CAM00149[1].jpg](https://forums.iboats.com/data/attachments/176/176514-50e969307ffd28c7fa115b7eb6916c5c.jpg)
![CAM00150[1].jpg CAM00150[1].jpg](https://forums.iboats.com/data/attachments/176/176515-3466340deb6079c9baebb716f9b73696.jpg)
dino
question,
dino
