Re: 1997 150 evinrude intruder still having fuel problems! any suggestions?
I had some similar problems and it was the pick up tube(I removed the screen because I have a filter/seperator on the new one, and removed the anti-syphon valve, and only put a original OEM Bulb.I had junk in my tank that would clog up the tube and anti siphon valve. I found it by adding a fuel pump vacuum guage ,I bought at harbor freight.It would run fine for a while at 1HG then out of no where raise pinging back and forth from 5-7hg which sets my alarm off. After that I have not had a problem. I also had a portable tank that my boat would run fine on.
