pafisher1234
Thread starter- Joined
- Oct 4, 2008
- 46
I am considering purchasing a 1997 225 Johnson Ocean Runner for 1875 and I am curious of common problems or problems I could run into.....also what I should look for ?
Im still unsure if I want to buy the motor. It's for a boat Im considering buying that has a 200 suzuki that he said the drive shaft snapped and needs a new lower unit. I may just rebuild that.
FYI - a 1997 225 did not come with a VRO system. It does have oil injection but it's not the old VRO system.
The 97's have the OMS sysytem which is different although they look similar. The OMS pumps are a basicially constant ratio pump and have much better alarm systems. Seen several cases where someone calls an OMS pump a VRO and ends up with the wrong parts or info.
