alanfox55
Thread starter- Joined
- Nov 17, 2011
- 476
It won't stay running under 1400 rpm without using the primer bulb. Rebuilt the fuel pump no change. I'm using a new hose and bulb and the primer bulb does get hard before starting. I did find a small leak at the oil pump but not in any of the hoses. The gas filter is half full and when I pump the bulb it goes lower then fills up while the bulb gets soft. I see no gas lines leaking and all the connections seem solid. Very confused please help.
