nola mike
- Joined
- Apr 22, 2009
- 6,046
Motor is toast
Motor is toast
So toast?
No, that was for AD. But I've already given my suggestions.So toast?
Oh ok. Yeah the only thing I haven't done diagnostic wise, is turn it by hand, I don't really understand how to do it. I did try to turn the flywheel with a flat blade screwdriver when I had the starter off. It didn't seem like it wanted to budge , And I didn't know if it was supposed to be able to turn that way , so I just put the starter onNo, that was for AD. But I've already given my suggestions.
Ok. So the boat is not worth a 10k+ motor replacement, I'm reading a 350 "yard block" and switching all my Marine parts onto it would work. I can pull the motor and put it back in, but how do I know exactly what to get? Like how do I know the motor mounts would be in the same place for example? Do I just match up the year and cylinder size? A 5.7L V8 Chevy from the same year?New larger cables and removed the switch
3 new starters
Pull the drive, that's the only thing left, and if it still cranks slow it has to be the motor
Yes I've already pulled the drive. The only thing I see that is concerning, is one of the two black o-rings is missing on the drive shaft is missing , and the orange one at the that goes into the engine coupler looks like it was stretched and maybe twisted, I don't know if that's just from pulling it off or if something happenedPull the drive first
The 305 and 350 use the same block, only the years can bring about holes missing as in maybe a ALT or raw water pump bracket bolt hole won't be there. Motor mounts stay the same
He still hasn't tried turning by hand.ok, than it has to be inside the motor
If you pull the heads you should be able to rotate the crank by hand. If unable to rotate by hand it's bearings
Yes i haven't. I googled how to do that, I see ppl removing the short bolts, and then putting long bolts in the harmonic balancer, to wedge a pry bar in between and crank it? If so , how do I know what bolt to put in there, take one of them out and take it to to a hardware store?He still hasn't tried turning by hand.
Nope it doesn't.With the plugs out grab the belt, you should be able to move it some
spun a bearing, maybe a piston crackedNope it doesn't.
Could be sticking valves as well (less likely if you can't turn with plugs out) or seized ps pump/alt. I'd remove belts, check oil, pull valve covers. But agree that if you can't turn it by hand you've got problemsspun a bearing, maybe a piston cracked
Okay I really appreciate you guys helping me diagnose this, I was completely stumped, and since I don't know much about the guts of an engine I figured something was going on beyond my ability. I'm coming to terms that I likely need to replace the motor.. It's lasted me for 15 years and probably has well over a thousand hours on it so I guess it was bound to eventually happen.Could be sticking valves as well (less likely if you can't turn with plugs out) or seized ps pump/alt. I'd remove belts, check oil, pull valve covers. But agree that if you can't turn it by hand you've got problems
You're looking to see that all the valves are opening/closing, no bent push rods, rockers in place. Turn engine by hand to feel for binding at a particular point, grinding etc. pulling a truck motor and swapping everything should be straight forward but usually a few speed bumps if the vintages are off. I don't know enough about year to year changes on the 350 to advise. I got my 4.3 from a junkyard Blazer for $180.
