This two cylinder engine has a consistent miss at all speeds; changed plugs, gas, checked timing, had carbs rebuilt, etc. The idle speed timing is set at 1 degree BTDC and at 5000 rpm it is 19 degrees BTDC, just what the Johnson book indicates. The idle screws have to be set out about 4 1/2 turns for the engine to run at low speed at all and the exhaust smells of raw gas. And the idle speed is about 1100 RPM, but I can't get it to run slower, it stalls (book says it should be 800RPM - Tach could be wrong). The compression is 139PSI top cylinder and 138PSI bottom cylinder so the reeds are apparently okay. Blew out the fuel lines, etc.<br /><br />This engine has a solenoid unit on the right hand side near the throttle and shift linkages. I think it is the electric choke solenoid as I can hear it click when I push the ignition key in. At its base is a Schrader valve stem with a grey valve stem cap attached. Beneath the cap and attached to the valve stem is an orange plastic pointer assembly. At idle, when this pointer is rotated CCW to the stop, the engine stalls; when rotated CW to the other stop the engine speed increases and then decreases somewhat. It runs rough at the "best" or mid range setting. There is about 90 degrees of travel for this pointer, from stop to stop. Can anyone tell me what this is and how to set it? Could it control the high speed air/gas mixture?<br /><br />Thanks
