Purchased pontoon boat with this motor 2 years ago was hard to start then but seems to be getting worse.
Staring procedures - pump primer bulb until firm, lift lever to about 1/4 throttle, turn key 1 notch press in for 10 seconds, and turn to start. Engine starts but only runs for a few seconds and dies, it will do this repeatly. If I turn the red lever on the electric primer to manual it will run but smokes alot, as it warms up I start turning the red lever back it smoothes out and will continue to run. Onces it has continued to run it starts fine the rest of the day. If it sets for 2 weeks we're back to not continuing to run.
This is what I did yesterday....
rebuilt electric primer, checked operation and for fuel flow - good
Sprayed carb cleaner into primer lines - no clog
Fresh fuel, new primer bulb, fuel line, fuel filter
Checked compression -125 in each cylinder- new plugs with good spark
Checked fuel delivery from fuel pump - strong fuel flow with every pulse to each carb.
Still wouldn't continue to run until I turned the red lever. Once it is warm and running it idles great and no hesitation or miss even at wide open throttle.
What am I missing with this problem any help would be greatly appreciated.
