FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have rebuilt the carbs drained cleaned and refilled the fuel and oil tanks changed the plugs checked the fuel lines checked the fuel pump vacuum it is under 3hg checked the fuel pump pressure it cycles from 3.5 to 6 psi at idle I am out of ideas
It sounds like the engine is going into SLOW, speed limiting overheat warning. The engine could be getting hot, defective heat sensor, faulty power pak.
thanks R.johnson but that was not it took the temp switch out and tested it it checked out ok checked the thermostat and it still surges will keep at it untell I get it
