1997 75hp Force prop question
Sipster
I have a '97 Force 75hp on a 22' pontoon boat. It has a 15 pitch 3 blade prop on it. Max RPM I get is about 4800. I can't seem to get more than 15mph out of the boat. I know it's a pontoon boat but i'm thinking I should get a little more. It seems to me that the lower unit on the engine is very small resulting in a small prop compared to other engines of that HP. Am I just being an idiot and that's the way it is?<br />Any advice would be greatly appreciated.......
WillyBWright
Re: 1997 75hp Force prop question
Welcome to iboats. :) <br /><br />A 15 on a pontoon? Too steep! You need a 12 or 13. That will allow the motor to reach full RPMs and full Hp. You might pick up a litte speed, but don't be too optomistic. 2 or 3mph will be about all. But you will avoid damage to the motor from lugging it. 2-strokes love RPMs. :) <br /><br />As you say, most other 75s use a larger diameter prop. I suppose it was to help keep the cost of the motor down. That, and the Force 75 is kinda weak compared to the others.
Sipster
Thanks for the welcome!<br />I was thinking the same thoughts. the 15 came on the engine from the dealer. I just always see other pontoons flying ( at least a little faster than me) I guess my expectations were a bit to high. I will try a lower pitch and let everyone know how I make out.<br />Thanks for the reply....
roscoe
Pontoon shape and design can have a major impact on speed.<br />A typical pontoon really starts to max out at 15-20 mph.<br /><br />Yes your motor has a small lower unit and prop. It is a "leftover" lower unit from earlier year 40-60hp motors.<br />Because of this, and other reasons, your motor (and mine) performs more like a 50hp than a 70.<br /><br />I run a 10.25 X 15p prop on my 16' aluminum v hull and get 5300 rpm. Think you will need a 12p to let the motor run right.<br />But don't expect much more top speed.
Sipster
Thanks alot for the input and advice!!!<br />I'll let you know how I make out..<br /><br />THANKS!
Sipster
I believe I have the same a 10.25x15 prop.<br />Looking at props available I see they go up to 10.75. Will it make much difference if I buy a prop a half an inch bigger? I was looking at a 10.75x12.<br /><br />Thanks!
roscoe
A slightly larger diameter prop will not hurt, may help a little, but not much. Pitch will have a much greater effect.
speeddemon1452
I have a 20 foot hydra poontoon with a 70 hp force 1995 and it has a 10 inc prop with 13 pitch and WOT is 4200 rpm. this boat is faster then any pontoon i have seen on the water so far, don't know if its diferent then the 75 hp force motor but fig i would tell you anyways
