1997 crestliner 4.3 merc outdrive water in motor sump
skipbehr
I keep getting quite a bit of water in motor well but no leaks on motor or hoses. If it is hooked up to muffs and run no water, but run it in the water and motor sump gets pretty full. Cant find where the water is coming in?
Bt Doctur
couple of possabilities:
main bellows cracked/ripped. water enters thru a vent hole just above the inputshaft behind the motor
shift cable bellows torn, water enters to the lower right of the inputshaft where the shift cable enters
exaust Y pipe rotted, water seen/heard trickling in under the motor at the transom area.
skipbehr
Thanks I will be checking these out. Thanks for pinpointing suggestions, much appreciated.
Fishermark
I wasn't sure what you were describing at first. Just to help keep things clear in the future, the "motor well" or sump is called the bilge. ;-)
skipbehr
OK :(water in the bilge) As the boat doctur suggested and checking this out .Looks like the shift cable bellows is ripped /Thanks for the replies and the diagnostics, Much appreciated..
