1997 Evinrude 130hp impeller/ waterpump replacement
fijian
Hi,
I would like to change the impeller on a newly bought 130hp 1997 Evinrude. I am yet to get a service manual. The tell tale looks pretty weak and someone said that once it heats up well, the themostat will open up? is that a correct statement?
I would like to service the impeller anyway so if any one can point me to the right directions on how to go about doing it..I would really appreciate it!.
also if someone can verify if this is the VL-90 degree model?
Thanks!!
wilde1j
Re: 1997 Evinrude 130hp impeller/ waterpump replacement
Get an OEM shop manual. It will tell all.
dazk14
Ensign
Pump replacement needed. Get a complete kit. Look on ebay for a reasonably priced factory manual. yes, V4 90 degree.
daselbee
First thing I do with a weak tell-tale is rout it out with 100 lb test fishing line and compressed air. See if it improves.
Secondly, you have two thermostats, one in top of each head.
C: :DWater pump replacement is not difficult, but can be tricky. Lots of gaskets, o-ring placement, sealant application, impeller key orientation.... Most first timers miss one or two bolts to drop the L/U, and miss disconnecting the shift rod. Fitting the impeller into the cup is a trick. And when putting the L/U back, most first timers miss the all important mating of the water tube to the output of the water pump.
It can be tricky. The OMC kits have instructions in them, but they are sparse.
Can you wait for your manual to arrive?
daselbee
Looking at your posting handle (nic), am I right in assuming you are from Fiji?
fijian
Thanks everyone for all the info, I have bought a Manual and am waiting for it to get here! I will attempt it after I get the manual and will post results!
Anymore info is still welcome though.
oh and Daselbee, you assumed correct!!
daselbee
You have a PM.
fijian
Thank you to all who replied! Special thanks to daselbee!
I got it done, actually the impeller seemed new so I cleaned and put it back in, I kept the new one for next season! Tested it at home and seems to be pumping pretty good!!
