1997 evinrude 40 hp tiller tilt assist
maineiac5586
Is there an alternative to the lever operated touch trim cylinder for my 97 evinrude 40 hp longshaft tiller ? It doesn't use the same bracket as a control equipped motor or else I'd think about adding a power trim unit.
tphoyt
I have heard that the 35hp rated unit will handle a 40hp 2 stroke but I would research that if interested. It’s a few $$$ less.
maineiac5586
That's why if you find the whole motor you get all the parts.
You think that whole bracket will swap over? I have a 48 hp longshaft parts motor but it's a regular controls motor and has the touch trim unit (non functional) . I wonder if I swap that bracket all I need is the power trim unit from another motor not a whole bracket
