1997 evinrude 50 prop choice.
steviecops
Re: 1997 evinrude 50 prop choice.
Sorry to jump in here, but is the tach setting recommended on this thread the same for an old 1980 2 cylinder 55hp? My engine has a rectifier but the tach is set on 6, which is what I was told to set it on. Should it be set on 5 or 6?<br /><br />Thanks<br />Steve
michaelj1978
Well the prop was a success. I took it out saturday night for a run at the lake. First with the 15pitch prop, then the 19.<br /><br />Boat is a Fisher Marine 18 foot flat bottom aluminum. Interior is fully decked out(storage/seating) and we had myself (200lb) my friend (230lb) and all of our gear, including a big cooler full of beer. Also there are 3 batteries and a topped off 6 and 2 gallon tank to give you an idea of the weight of the boat. <br /><br />I also hooked up the GPS (eagle 320) with the hotmaps which worked great. If you don't have GPS and a map like this get one!<br /><br />With the 15 pitch I was only able to hit 19.3mph without the motor starting to over rev. Took off the prop and threw on the 19 pitch and we topped out at 26.9mph. I don't think this boat's ever been that fast! Felt like a whole new boat. Motor ran great and sounded like a motor should. We had no problem getting the boat to plane and once up, tilted the trim back and skimmed the rear 1/4 across the water.<br /><br />Water temps were also in the low 50's and we had a little wind. I think on a warmer day with less wind, less weight in the boat, I might be able to hit 29-30mph.
moderator1
The most important item is that you reach Max recommended RPM...speed means nothing. Gotta know what the tach says or we'll be puttin' another engine on that boat.
michaelj1978
I played with all the settings on the tach and it still read high. The motor still had enough power to cavitate/ventilate and still spin really high. I'm taking it in this week to get another tach hooked up and a full service on it.
