mattandapril
Thread starter- Joined
- Jan 23, 2016
- 5
I have a 1997 force 120 that has electrical issues, the tach was not working and I traced to problem to a bad regulator, I checked stator and the ohm readings were fine and it puts out 38vac between 2 yellow wires. I replaced regulator and it was either defective when received or it blew as soon as motor cranked. I am thinking about replacing stator and regulator Is there anything that would cause regulator to blow or is the stator over loading it? Thanks for any help.
Matt
Matt
