1997 Force 40 HP charging
Big Fish Billy
Hello There,
I recently bought a boat with a 40hp Force. I'm wondering if the motor recharges the battery as it runs?
Thanks,
Bill
jerryjerry05
Re: 1997 Force 40 HP charging
It should.
Get a volt meter or someway to measure voltage.
Check voltage when it's off.
Then as it runs see if it changes.
Slow operation won't always charge the battery, sometimes it needs to be run faster than an idle.
Big Fish Billy
Okay Jerry I'll give that a try, thanks. Bill
roscoe
All you need to do is connect the volt meter to the battery terminals and check the reading when not running.
Then check at about half throttle. It should be above 14 if it is charging.
Big Fish Billy
Okay, I'll report back when I run it again, thanks.
Big Fish Billy
Thanks everyone, it was about 12 before starting and went up to 15 at a fast idle.
