1997 Force 40hp
Big Fish Billy
Hello,
I just bought a boat with a Force 40hp, noticed no tell tale pee hole. Has anyone added this to their rig and can recommend parts to use. When I first ran the engine I took the little 1/4" plug off the top and no water pressure. I figured the impellor was gone, so I took apart the water pump, impellor was fine but the upper gasket had blown out the front. Is this common?
Thanks,
Bill
wickware
Re: 1997 Force 40hp
1. Can you post a picture of your blown gasket ref? Or! Show the gasket in a parts diagram.
2. Did you test for water pressure deep in a 55 gallon barrel, in the lake/river Etc?
3. Attached is my Tell Tale on my 1970 35 hp Chrysler (through base vs cover). All parts are form Hardware, Etc.
Big Fish Billy
Re: 1997 Force 40hp
Hi there,
It is the far right gasket top row, from your parts dept: http://www.iboats.com/mall/image/vendor/16/bigger/18-3214_big.jpg. I had run the engine with a hose before buying it with earmuffs and not water at the top plug. Guy took $200 off, so when I got it home, I dropped the housing and checked the pump, impellor was fine, but the front end of that gasket had blown out. I double cut a small piece of gasket material in, added some goop and put it back together, water was pumping good, just would like the pee hole deal and wondering if there was a special kit somewhere. I've tracked down some parts and will get an arrangement made up. Thanks for the help. Bill
roscoe
Re: 1997 Force 40hp
Generally you need to submerge the lower unit in water to get it to pump correctly. They just don't like to fill with water with the water muff design and shape of the lower unit.
Might want to replace your thermostat as well.
there should be a 1/4" pipe plug in the top of the head, just ahead of the thermostat.
Remove the plug, install brass fitting with hose barb, add 4 feet of tubing, route to exit point, drill hole for tubing. Presto, done for $7 and a trip to the hardware store..
http://forums.iboats.com/force-chrysler-outboards/can-i-add-telltale-force-210027.html
wickware
Re: 1997 Force 40hp
The solid water stream vs exhaust mixed and pointed away more to the side, made this a winner for me. This is easy on the Young Neck. LOL.
Plus, check your over-heat alarm/sensor to know it?s working. If I ground my sensor?s electrical connector at the orange wire to my head (attached), my horn sounds with the switch on. You might have a light buzzer or etc. The sensor acts as a ground when the temp is above normal. To actually test the sensor you need to heat it in water to see if it closes as a ground with an ohm meter or etc.
jerryjerry05
Re: 1997 Force 40hp
Most important is what wick was telling you.
The lower unit needs to be DEEP in the bucket.
2-4 inches over the cavitation plate.
Also low water pressure on the hose or the muffs not fitting right.
The pump isin't a self priming pump.
It needs water to be pushed up to it or submerged in it.
Big Fish Billy
Re: 1997 Force 40hp
Thanks guys, located a plastic drum to cut up and make a nice test bucket, also got some brass fittings to make up a pee setup, I'll post some pics when I get it set up.
