1997 Force 75hp, water pump problems
dontalkmch
I started the motor and noticed no water being pumped out, I checked the port for debrie with a wire and it was clear. I brought it home and drop the lower unit and the impeller looks good, i replaced it anyway just to be sure. but it still isnt pumping water out of the port can anyone help?
12Footer
Re: 1997 Force 75hp, water pump problems
You didn't mention the thermostat. Pull it, run it for 5 or 10 minutes without it, (provided it is blowing steam out of the exaust)and install a new one.<br />The reasoon for the "runnin without for a few minutes" is to flush the entire water jacket.<br />Also, don't trust ear muffs on Force motors. They have a wierd intake that doesn't allow a good seal. It takes a special square-type muff, and even then, it's "if-y" on a proper seal.
dontalkmch
It does blowe smoke out of the exhuast, I'll try pulling the thermostat and give it a shot,<br />Thanks
dontalkmch
That did the trick, The thermostat was stuck, I didnt even think of that.<br />thanks alot, I appreciate it!
