Dukemeister
Thread starter- Joined
- Jul 26, 2013
- 27
Hi folks,
Saga continues trying to get this old motor to run. Had the stator and power pack replaced, cleaned the carbs and it runs. It idles a bit rough but starts quickly and runs, but at idle on the muffs it will stall after about 5 min, seems it runs out of gas. If I pump the fuel line bulb it will catch and keep running and I can watch it and when it starts to slow down, pumping the gas bulb gets it going good again. I think this means fuel pump is bad... correct?
Also, the VRO seems to be mixing and delivering OK, because blue fuel is in the carbs. But, sometimes just before it stalls (if I don't squeeze the bulb) the VRO alarm will sound. The alarm stops if I squeeze the fuel bulb and the engine idles on merrily. Is this a "normal" condition with a bad fuel side of the VRO pump? Reason I'm asking is because a rebuild kit is only $150 for the fuel side but a new pump is like $500.
Thanks, Duke
Thanks, Duke
