Model # J70TLEUM. Hope someone knows the answer my local marina/dealer has no clue. Replaced the impeller and housing and found no o-ring under the impeller yet the factory 97 parts diagram show one under a 3 vane impeller. Mine has a 6 vane and 98 diagrams show no o-ring under a 6 vane impeller. Possibly a mid season change. I am getting water in the gearcase but it has been resealed am thinking it's going through the driveshaft hole in the plate onto the driveshaft seals. What's the point of a gasket under the bottom plate if water can come through the center hole. Seems odd to put an o-ring under a rotating part. The aftermarket impeller kit (BRP kits backordered for weeks now) didn't come with one and impeller doesn't have a groove for one and if I install the one called for the housing doesn't sit flush on the plate cause of the o-ring. So do I o-ring it or not.
