1997 johnson 70 vro
seminol7
:)will idle out of gear,but put in gear will idle for 2or3 minutes and will die.Runs great at higher rpm.out of gear rpm is at 1000 in gear 600-650.will crank back up no problem.any help will be great!
SparkieBoat
Re: 1997 johnson 70 vro
get a spark gap tester..should have blue streak at 7/16 gap, remove and clean carbs, pay careful attention to all of the small holes, check all fuel lines/filters. new plugs if its been a while. Did this just start or has it been going on for a while?? has anyone messed with any of the adjustment screws?? sounds like maybe idle screws out of adjustment.
seminol7
just bought boat been in water 5 times since i owned it.replaced plugs set gap at .35.took carbs off cleaned.do you know how many rounds to get a starting point on adj.screws?they were 3 rounds.Thanks for any and all help
tashasdaddy
the jets are not adjustable. the idle screw is start a 4 out. these engines were built to run, not idle.
kenmyfam
Agree completely with TD. They don't like to idle !!!
SparkieBoat
remove your idle air screws and make sure they havent been hard set causing a shank on the needle part. then soft set each one in and back out 4 turns. Adjust 1/4 Counter clock wise first and see if it gets better or worse, then adjust as needed 1/4 turn at the time, do this on the water and run for about 10 mins in between adjustments, going back to idle a couple of times then throttling up. also check your timing
seminol7
Thanks to everyone!from what I read it's probably going to be the air idle screws since they were set at three rounds out.Will try on the water as soon as possible.If it were to be a timing problem how and where do I set?Again thanks!
seminol7
Thanks to all that helped,took to water runs alot better on idle adjustment!Still needs a little more adj.but a whole lot better.Again THANKS!
