1997mercury
- Joined
- Oct 27, 2009
- 12
I have a 1997 Mercury 175 offshore. I changed the fuel lines and spark plugs as I just bought the boat. Has aluminum tank and lots of fuel ran in it, I do not think its an eth issue. Problem: After traveling through a no wake zone for a bit it requiers me to throttle up as it starts to spudder out but will idle in the driveway all day, also it is hard starting only after running for a while. I have to wide open throttle and choke it to start it. But in the driveway it fires right up. ??? It runs great at 1/4 plus throttle with no issue, just the starting and low speed travel I have issues. Also I am not sure if this is an issue but the fuel ball goes soft after running it for a while but is hard in the driveway. I checked the lines and have no visible line leak/air leaks. I was told it sounds like a carb adjustment issue, I have no idea. What say you?
