1997 mercury 115hp outboard power trim help
meatyb
hi all i have a 115 mercury 2 stroke outboard 1997 the power trim leakes on the down stroke and when motor is all the way down i hear air bleeding out. from the up postion when i trim motor down it leaks from the top of the ram.(o rings i guess) but cant find any rebuild kits cant find and part or serial numbers on unit. (prevouis owner kept boat in salt water ) so cant make out any numers any help would be great thanks
Chris1956
Honorary Supreme Mariner
Re: 1997 mercury 115hp outboard power trim help
Loioks to be two types of PTT on that motor, depending on serial number. Check it out at crowleymarine.com web site. Here is URL for an oring set for the PTT. I do not know if it is the correct one however.
http://www.crowleymarine.com/parts/309804.cfm
meatyb
thanks i shouldve mentioned it was a single piston. now just have to figure out how to take it off:confused:
