1997 Mercury 150a
Dukedog
do timin' anytime ya change any of these, trigger, stator, switch boxes..
backfire, check all trigger, stator, switch box wirin' ta make sure right color wire goin' ta right terms/coils...
gas thing is gonna be either and/or floats, needle, seats, internal gaskets............
Worm0129
Dukedog, I checked and triple checked the wiring from stator to switch boxes to coils. I have the outside switch box wired with the striped wires, then to the 2,4,6 bank of motor. The timing is so far off that I can only see the timing numbers when I have the light on the #2 plug wire. I looked at my phone photo from before I took it apart to replace parts and it looks as if the 1,3,5 coils were on the OUTSIDE switch box. Do I change it to 1,3,5 = outside and run it that way? I'm not sure I can get the timing to move far enough the way it is. Wire diagram I'm using is: http://www.maxrules.com/oldmercs/Wiring/1966ona/52.jpg
Dukedog
i ask for an email address to send you a pdf manual and i didn't tell ya ta do it in a "PM" (private message)
