1997 Sea Rayder
Rusty - da - Realtor
Hello All,
I just purchased a 1997 16 ft Sea Rayder with a 175 hp v6 mercury 2 stroke. I paid $2000 for the boat. It has 350 hrs on it. I don't even know if the thing will run. It has been sitting for quite some time. I was planning to add a new bettery, remove the spark plugs and squirt an oil gas mixture into the cylinders, hook up the water hose and try to fire it up. Does this sound like a good plan? Are there any precautions I should take? This is the first boat I have ever owned. Thanks in advance for your advice and your patience.
Russell
rndn
Re: 1997 Sea Rayder
If it's old gas, remove it and place fresh gas mix into the tank. Check the pee stream for water flow if it starts running and shut it down if you don't see water flowing after a minute or so.
