Coreye2044
Thread starter- Joined
- Feb 25, 2013
- 8
I have been chasing a surging issue at idle for a year now. The engine runs great at WOT. it sometimes runs fine at idle and then sometimes doesn't, it will surge. Things I have done
Compression test - everything fine @ 120 psi.
Rebuilt carbs
Link and sync
Adjust low speed jets to spec
Tested coils - there was some corrosion were the coils grounded/bolted to the CDI assembly so I wire brushed it off and still no difference.
Tested spark on port side and noticed there was very little to no spark on all three cylinders. When I say weak, I mean I had the spark gap on the tester almost touching and it was barely arching.
Tested spark on starboard side and spark was great. When I say great I mean gap of an inch would get good spark.
After the spark test it led me to believe this was the cause of the surging.
What I need help with is the next step. Should I test - CDI (is there a way to test?), stator, or is there a switch that kills those three cylinders when shifting in and out of gear? Any help would be highly appreciated.
Thanks!!!
Rebuilt carbs
Link and sync
Thanks!!!
