1998 115 in storage for six years...
273DC
i have a 98 johnson 115 (unsure of exact model number at this time) that has been in storage on by stratos 98 273 for the last six years. it was bought new, ran for two seasons then put in storage. she has a full tank, sta-bil and the rig is up on blocks.<br /><br />i read through the sleeping outboard FAQ and it was good, but i wanting some advice from other j/e owners out there who may have experinced something similar.<br /><br />thank you
alden135
Re: 1998 115 in storage for six years...
I'd get rid of the 6 year old gas no matter how much Stabil is in it.
OBJ
Welcome 273DC!<br /><br />The FAQ pretty much says it all and is an excellent guide to getting the engine water ready again. Don't know there is much more to add unless you have a specific question.<br /><br />And yeah! What alden said!.... :)
273DC
thank you for the welcome and the fast responses.<br /><br />basically, is there anything in particular that applies to my specific engine... i do not have a service manual yet but will purchase one. is it a relatively easy task to get this thing going again? should i drain/flush the tank and just fire it up to see if it will run first? if not, are there other steps i should do (beyond the FAQ) before?<br /><br />thanks again.
273DC
Originally posted by alden:<br /> I'd get rid of the 6 year old gas no matter how much Stabil is in it.
no doubt. anyone know if there is a direct drain for a 98 Stratos 273... or will i have to pump it out?
tashasdaddy
if you can get to the fuel gauge sending unit, you can open it, and use a hose small enough to go thru the stearn drain hole and siphon it. do you know anyone you can borrow a 6 gallon tank from.
273DC
ok, the model number on my warranty card (have not got the boat out of storage yet) is J115GLEC. i have only seen service manuals for the SPL... i have no idea what the different models are.
alden135
GLEC<br /><br />G=special styling<br />L= 20"<br />EC= 1998
rickdb1boat
On draining the fuel. You should be able to disconnect the fuel line from the motor, take the fitting off and use the primer bulb to get flow going and syphon it out that way if you get the recieving containers lower than the fuel tank in the boat.
Solittle
To follow Rick's lead - - See if you can run the fuel line through the drain hole at the bottom of the transom.
rickdb1boat
See if you can run the fuel line through the drain hole at the bottom of the transom. <br />
There ya go.... ;)
273DC
Originally posted by SoLittle:<br /> To follow Rick's lead - - See if you can run the fuel line through the drain hole at the bottom of the transom.
is there enough line to do this you think? again, the boat is not with me yet and i need to make a list of what i need to bring to get her at least on the road with the trailer before towing it back. thanks again.
273DC
Originally posted by tashasdaddy:<br /> if you can get to the fuel gauge sending unit, you can open it, and use a hose small enough to go thru the stearn drain hole and siphon it. do you know anyone you can borrow a 6 gallon tank from.
what am i doing with the 6 gal. tank??? if i recall, the boat has a 32 gal. tank. thanks.
rickdb1boat
DC<br /><br />Hopefully you can run the fuel line out through the drain plug hole in the back of the boat instead of going up over the gunwale(Better draining on a down hill slope). I don't know if there will be enough fuel line to reach a container that would be sitting on the ground behind the boat to catch the syphoned gas. Might want to pick up some extra fuel line and a barb to splice it into your existing fuel line. I think the reference to a 6 gallon tank was for testing purposes. In other words, hook up a portable 6 gallon tank with fresh premix in it and use that to find out if the motor will run well. But that is neither here nor there, as you have to get the fuel out of the built-in tank no matter what. I would buy a couple of 5 gallon containers to syphon the old fuel into. Of course, you will have to have a plan to get rid of it as it is draining(Kinda hard to get 32 gallons into two 5 gallon cans). I don't have an answer for that one. Maybe drain 10 gallons, pinch off the drain line and take it to your local waste recipient if they will take it. Might have to call around to find someone who will take it. I have run small quantities of older drained fuel in my car before. But nothing that old, so I don't want to suggest you do that without knowing the state of the fuel and the effect it might have....
273DC
disposing of the old fuel will be an issue. there is a marina near by that may be able to assist me but i won't know about that until i get there. of course i could just tow with the tank full and get this done once it is back.<br /><br />so far i have not been able to locate a manual for my engine (that i know of). all the ones i see are for 90/115 "SPL" whatever that is. will this work for mine as well?
rickdb1boat
Did you try ken cook for a Manual? And you might just want to bring it home full and deal with it there....(SPL =Special, meaning a stripped down version, with no VRO or Tilt and Trim, of a 115 usually designated as a 112 HP)<br /><br />kencook.com/evinrudejohnsonmanuals/
273DC
thanks Rick. i will check the site. nice to know about the enignes as well. seems like everywhere i look all i can find is the manual for the special.
273DC
rick - the site only goes to 1996. are the engines similar between the model years?
273DC
just found one used near by for $25. this is for a 97 but they said it would cover a 98 for what i need to do... think this is the case?
